Activity › Forums › Square Box CatDV › Worker node – exclude a folder?
  • Worker node – exclude a folder?
    Posted by Jeff Nielsen on February 3, 2011 at 8:16 pm
    We’re currently evaluating CatDV Enterprise with worker nodes to possibly purchase. I’ve got the worker node scanning our networked projects folder and successfully adding the assets as I want it to, but I’m wondering if there is a way to exclude by folder name. So, if I don’t want anything added to the catalog from any folder named “restored” can that be done? The reason is we end up restoring old assets often into a project and don’t want to re-archive them or even input them into a catalog. I know it can exclude by file name or type, but I’m wanting it to skip over any folder named “Restored”. I see this problem going away over time as our projects become CatDV centric, but for now I would just as soon not have these old assets in the catalogs.
    Rolf Howarth replied 15 years, 7 months ago 3 Members · 2 Replies
  • Bryson Jones
    February 3, 2011 at 10:57 pm
    I’m not aware of folder exclusions, but perhaps Rolf can speak to it. (not a bad request, actually)
    I will say that I’m sure there’s a way around it but not knowing your system or workflow, it’s hard to start. (and way too much to type!)
    A short idea is that you let CatDV scan it, but set an action that if the “BIN” name or path contains “restored” it could go to a “recycle” bin instead of the one it gets picked up into. Again, just one idea.
    I, myself, don’t usually have the Worker scan a working directory. It’s normally watching a folder and then moving the data into a structure while adding things to a catalog. Users drop into a “drop” and that gets filed away by CatDV. But in a big SAN I totally see why you’re working that way.
    bryson
    bryson “at” hidefcowboy.com
    hidefcowboy.com
  • Rolf Howarth
    March 3, 2011 at 9:30 am
    Apologies for the long delay in responding but you should be able to do this using a regex filename exclusion pattern in the Conditions tab, something like
    /restored/
    to match for “restored” occurring anywhere in the path, or
    .*/restored/[^/]*$
    to exclude files only whose direct parent is “restored”.
    Quick regex tutorial: [xyz] matches characters inside the square bracks, ^ negates the match, * means any number of occurrences, . matches any character, and $ matches the end of the text string. So, that pattern says match anything followed by “/restored/” followed by any characters excluding “/” up to the end of the path name.
