Worker node, conversions, and server
Helping a client with their CatDV Professional Edition (10.0.5):
Hopefully I’m missing something obvious that’s somewhat straightforward to implement. They have CatDV Server set up, with Worker Node on ingest Mac and CatDV Pro on 3 other networked Macs (each used as editing workstations). Here’s their goal for preferred workflow:
-1 They place raw footage (transferred from camera cards or drives) in Encode Folder on Mac used for ingesting.
-2 Worker Node is watching Encode Folder and converts videos to ProRes (retaining metadata from camera, etc)
-3 The new converted ProRes file is published to the server, copied to Server volume, and appears in Inbox catalog on CatDV Server
-4 The metadata from the original video file is retained for each converted file
-5 The CatDV media path now refers to the converted file, not the original
-6 The original video files get moved to a Processed folder
-7 The editors use their local CatDV Pro to select footage from CatDV Server, then copy selections to their local storage.Here are my problems. Steps 1 and 2 are working, using Watch Actions and the Conversion tab with Worker Node, EXCEPT for metadata passing along to the converted file. Step 3 is working (except for metadata). And the biggie: Step 5 is not working — convincing CatDV to change its media path to refer to the new converted file, NOT the original video. (Step 6 is optional – nice to automate it, but can be done manually.)
Their reasoning is: when they locate footage they want to use, they want to use it now, without converting it. In other words, converting to ProRes on ingest to CatDV instead of what seems to be default behavior of ingesting originals and then converting as needed.
I would appreciate any suggestions and tips on implementing this (or even alternate workflows).
-Philip.
