Activity Forums Square Box CatDV Worker multiple cmds with variables
  • Worker multiple cmds with variables
    Posted by John Heagy on October 17, 2011 at 9:51 pm
    How do I run multiple commands in Post-Processing? If I type two commands in line separated by a comma (xxx, xxx) it ignores the second command and uses the (,). If I make a .sh with the comma separated commands the variables are not respected.
    John
    Rolf Howarth replied 14 years, 10 months ago 2 Members · 3 Replies
  • Rolf Howarth
    October 17, 2011 at 10:33 pm
    You might be able to do something like
    /bin/sh -c “command1; command2”
    but I haven’t tried it. The best thing is probably to write a shell script that executes the two commands you want, passing your arguments to the shell script and then referring to them as $1, $2 etc. in the shell script.
  • John Heagy
    October 17, 2011 at 10:56 pm
    Hi Rolf,
    I can get two commands to run in a shell script but the CatDV variables are ignored. Are you suggesting I set the variables somehow 1st? Wouldn’t that require yet another command?
    I did manage to do what I wanted by using the 1st execute command in “Conversions” then the 3rd in Post-Processing”
    Doing it via a shell script would be great if the CatDV variables expanded.
    John
  • Rolf Howarth
    October 18, 2011 at 7:38 am
    Where are you writing the CatDV variables such as ${U1}? That syntax is only understood on the command line itself, it won’t work within the shell script.
    Command 1: myscript.sh
    Then a s shell script that contains the following WON’T work:
    #!/bin/sh
    echo User1 = ${U1}
    Instead, you need to do
    Command 1: myscript.sh ${U1}
    #!/bin/sh
    echo User1 = $1
