Activity › Forums › Apple Final Cut Pro Legacy › Workaround to display creation date for clip?
  • Workaround to display creation date for clip?
    Posted by Trevor Asquerthian on February 5, 2011 at 6:34 pm
    Someone clever must have figured out how to get creation date metadata from QT file into one of the columns in FCP…
    Is there an automator workflow? I can’t figure out how to do it with macros because I can’t access the date in a QT file from a keystroke…
    Trevor Asquerthian replied 15 years, 7 months ago 2 Members · 2 Replies
  • Andreas Kiel
    February 6, 2011 at 12:14 pm
  • Trevor Asquerthian
    February 8, 2011 at 9:49 pm
    Hi Andreas
    Looks like it could do. It borked on a folder of H264 clips (just crashed out). I’ve just tried it on a folder with only 1 SD_DV clip in it, which I gave a reel name of ‘test’ before running auxtc on it.
    The resultant xml, when imported to FCP, reports
    “Tue, Feb 8, 2011, 21:43 – Errors Found Importing t.xml
    : Unable to attach specified media file to new clip.”
    The ‘media offline’ clip reports it’s reel as 20110208 (rather than test) – matching the aux1 and aux2 reels.
    It did work on a different clip though….
    I’ll play around some more if I can find some proper media.
