Activity Forums Adobe Encore DVD Work space too large
  • Work space too large
    Posted by Gerry Condez on March 5, 2014 at 2:24 am
    Is there an option to fit the workspace in my 20 inch monitor? I cant go to the bottom of the timeline or library to select other options. thanks
    Gerry Condez replied 12 years, 6 months ago 2 Members · 2 Replies
  • Jeff Pulera
    March 5, 2014 at 4:24 pm
    Hi Gerry,
    The size of the display is not necessarily the issue – rather, it would be the display resolution. Right-click the Windows desktop and click Properties to bring up the display settings. See if you can increase the resolution used.
    Jeff Pulera
    Safe Harbor Computers
  • Gerry Condez
    March 5, 2014 at 6:07 pm
    Thanks, But what if the resolution is maxed out? Its 1680×1050. its a 20 inch cinema display. Is there a keyboard shortcut or option to fit on screen? I cant drag the whole workspace up so for short, I cant resize the window since the lower right corner can not be adjusted.
