Activity Forums Apple Final Cut Pro Work flow with multicam, color correction and audio editing
  • Work flow with multicam, color correction and audio editing
    Posted by Claude Lyneis on September 16, 2017 at 3:55 am
    I am working on a multicam edit of an interview with two cameras and two lavs. It is clear that the exposure levels of the two cameras were not well matched so at some point the lift, gamma and gain will need to be adjusted to make them match. In addition the audio has a fair amount of background and some of that could be rolled off or cleaned up. The first interview runs 15 minutes, but in the end will be cut down to no more than 1 minute. Should I just take the clips uncorrected, edit away on the multicam cuts and then do the color correction and clean up the audio afterwards?
    I would seem tempting to do the gross color matching before all the cutting between the two cams, but since you can only color correct in a project and not on clips in the browser, is that even feasible.
    Thanks.
    Jeff Kirkland replied 8 years, 11 months ago 6 Members · 10 Replies
  • 10 Replies
  • Jeff Kirkland
    September 16, 2017 at 6:24 am
    I will usually colour correct one of the cameras by applying the effect to the clip inside the Multicam editor.
    Jeff Kirkland | Video Producer & Cinematographer
    Hobart, Tasmania | Twitter: @jeffkirkland
  • Noah Kadner
  • Kathy Murphy
    September 16, 2017 at 7:19 pm
    I’d definitely do it before starting to cut.
  • Claude Lyneis
    September 16, 2017 at 10:55 pm
    I have to test it out, but I think if I color correct at the beginning of the multicam edit, first with one camera selected and then with the other, those corrections stay with the clips as I cut from one to the other. That should save some time and provide a consistent starting point for some fine adjustments at the end of the edit. Normally, you can’t color correct clips that reside in the browser.
  • Jeff Kirkland
    September 16, 2017 at 11:43 pm
    If you’re talking about doing it in the timeline, your way will work but If you colour correct inside the multicam editor you can go back and make changes to the grade globally, even after the edit.
    If you want to grade a clip in the browser, then right click and choose Open Clip. Apply the correction there. But if you go back and make a change, it won’t ripple downstream to the timeline.
  • Steve Connor
    September 17, 2017 at 2:57 pm
    [Jeff Kirkland] “If you want to grade a clip in the browser, then right click and choose Open Clip. Apply the correction there.”
    This is an important tip for everyone!
  • Noah Kadner
    September 18, 2017 at 9:23 am
    Grading the entire take within the multicam assumes the image doesn’t change much throughout the take- which can be true or not depending on your specific footage. So choose workflow accordingly.
    Noah
    FCPWORKS – FCPX Workflow
    FCP Exchange – FCPX Workshops
    XinTwo – FCPX Training
  • Bret Williams
    September 18, 2017 at 2:51 pm
    The important part was the warning that it doesn’t ripple down to the timeline. 😛
    _______________________________________________________________________
    https://BretFX.com FCPX Plugins & Templates for Editors & Motion Graphics Artists
  • Claude Lyneis
    September 18, 2017 at 4:48 pm
    I agree. For this application, it is a static interview with fixed lighting. So it should save time to grade and color correct the clips from each camera before cutting between the two in multicam. Of course the other approach would be to cut everything, then select all the subclips from one camera, and apply a correction across all of them at once.
  • Jeff Kirkland
    September 18, 2017 at 9:02 pm
    Any pre-timeline correction is going to be global just correcting any overall imbalance between the cameras.
    The reasons I do that with clips inside the multicam editor is that a) it does ripple back to the timeline if I want to go back and modify it after I’ve started cutting and b) I have the multicam viewer available so I can see all the other clips for reference while I’m tweaking.
