Activity Forums Apple Final Cut Pro Legacy work flow suggestions
  • work flow suggestions
    Posted by Coach on September 30, 2006 at 10:32 pm
    hello,
    I have few questions regarding some work flow suggestions and some tech questions. Normally I just edit dv footage that I shoot and import into FCP 4.5 and edit it. No big deal. I had a client approach me about taking one homemade dvd 4.7GB made in iMovie with menus (they made and own all the rights) and a Fuji mini 1.4GB minidisc unedited shot on a Sony and combing them onto one disc.
    Questions:
    I edit on a 17″PB, 1Ghz, can I put the mini disc in the dvd slot and will it load and play and can I get it out by ejecting it? How will I get the material off of the minidisc disc? If I can load it should I make a disc image copy? I am just not sure here…
    How can I get both videos on to new DVD-R discs? The customer wants to combine the two pieces (each disc) that are currently on seperate discs onto one new 4.7GB disc. I am not sure how to make this happen.
    I could really use direction on this one as it is out of my standard work flow. Will I even need FCP on this project?
    I hope I have made myself clear about what I have and what I need to do. Thanks for any suggestions.
    Coach
    Coach replied 19 years, 11 months ago 2 Members · 2 Replies
  • John Pale
    September 30, 2006 at 11:15 pm
    Not sure if your laptop can play this mini-sized DVD, but assuming it can, you really dont need FCP for this, if you have DVDSP.
    Copy the VIDEO_TS folders from both discs onto your hard drive.
    Use MPEG Streamclip (available free) to demultiplex the relevant video files. Assemble them onto a video track (or tracks) in DVDSP and create a new DVD.
    You should have your client assume the risk for repair, if this mini-sized disc gets stuck in your computer.
    MPEG Streamclip available here: https://www.squared5.com/
  • Coach
    October 2, 2006 at 4:14 pm
    John,
    Thanks for the help. I took the mini disc copied it on to a standard disc using my plextor dup. tower. That went great. Which setting/task should I use now that I have the necessary folders on my desktop using MPEG Streamclip? I do use DVD SP3 also. Thanks for your help.
    Coach
