Activity Forums Avid Media Composer work flow question
  • work flow question
    Posted by Bear Baker on May 11, 2006 at 12:04 am
    I have a client that wants to do a 1 hour dock with HDV and Beta SP footage. I will offline on my Avid XPress Pro 4.8.1 on an older Mac G5 dual 2.0. I don’t have Mojo… yet. If I need it for the Beta SP I will buy it. Online will be done on a “suped up” PC running Adobe Premiere. The online guy wants AAF files with media. I plan to offline at DV-25 for HDV. How do I get the Beta SP to the DV-25 codec? Do I need to? Do I need to buy a Mojo?
    Thanks for any help,
    Bear Baker
    Oliver Peters replied 20 years, 4 months ago 2 Members · 3 Replies
  • Oliver Peters
    May 11, 2006 at 12:14 am
    [Bear Baker] “How do I get the Beta SP to the DV-25 codec? Do I need to? Do I need to buy a Mojo?”
    Cheapest solution is to dub to DV if you have a deck or better yet, get a simple Canopus converter. Make sure you control the Beta deck with RS422 and use a burn-in to double-check frame accuracy.
    Sincerely,
    Oliver
    Oliver Peters
    Post-Production & Interactive Media
    Orlando, FL
    http://www.oliverpeters.com
  • Bear Baker
    May 11, 2006 at 1:09 am
    I’m new to Avid. I have a Mac with FCP/Black Magic that has a RS422 port on it. I noticed the Mojo has no RS422 control. How do I get RS422 control out of my Mac? I looked for USB-RS422 9pins and found nada for the mac.
    Bear
  • Oliver Peters
    May 11, 2006 at 1:12 am
    Generally most folks use a Keyspan USB-to-RS422 adapter for the Macs.
    Sincerely,
    Olive
    Oliver Peters
    Orlando, FL
