Activity › Forums › Apple Motion › work flow from motion 2k project to Cinema 35mm upload
  • work flow from motion 2k project to Cinema 35mm upload
    Posted by Mohamed Mira on October 3, 2005 at 6:03 pm
    Hi all
    I’m a new to motion2
    My concern is that i need to find a work flow to produce 2k film intro in motion2 then upload it to a 35mm reel.
    will any one help me, even theorically and i’ll try that my self and post the results later
    lookin for yr advice soooooooooooooon
    best regards
    Mohamed Mira
    Mohamed Mira replied 20 years, 12 months ago 2 Members · 2 Replies
  • Jim Kanter
    October 3, 2005 at 9:35 pm
    Would this be all-original graphics, or would you want to import and use video clips?
    You would need to work at the 2K frame size in 32-bit float color space. You will need to have the biggest, baddest dual-G5 with high-end video card and lots of RAM to work reasonably at those specs.
    For outputting you would check with the filmout service bureau as to the best file format for them to work with.
    Jim Kanter,
    Digital Film Institute
    http://www.dfilminst.com
  • Mohamed Mira
    October 4, 2005 at 5:55 am
    Dear Kanter,
    I guess it will be all original graphics.
    But, what if I may import some video clips? Any rolls to follow
    Could I have a very small info about file format that could be transferred to film, Or a web link with that info.
    Thanks a lot for yr advice
    Best regards
