work flow from HD to SD
Hello,
I’m taking 3/ tapes and digitizing the footage through BrightEyes 25 Analog to SDI into a Sony XDCam HD PDW-F70 deck. After digitizing I am exporting to both Blue-ray and DVD formats. However every time the sequences render the audio ends up 10 seconds out of sync. I have tried both the following sequence settings and work flows:
Frame Size – 1440×1080 with HD(1440×1080) (16:9) Aspect ratio
Pixel Aspect Ratio is HD(1440×1080)
Field Dominance is Upper (Odd)
Editing Timebase is 29.97
Quicktime Video Settings
Compressor HDV 1080i60
Quality 100%
Audio Settings
Rate 48 kHz
Depth 16-bit
Config Channel GroupedVideo Processing
Render in 8-bit YUV
Process Maximum white as Super White
Motion Filtering Quality Normal-AND-
Frame Size – 1920×1080 HDTV 1080i (16:9)
Pixel Aspect Square
Compressor Uncompressed 10 bit 4:2:2
Quality 100%
Audio Settings
Rate 48 kHz
Depth 16-bit
Render in 10-bit material high precision YUV
Motion Filtering Quality NormalNo matter the settings the audio is out of sync. I have tried taking the sequences both through Compressor (DVD best quality 90 minutes) and Quicktime Conversion.
If someone could explain what is wrong with the settings I am using I would be extremely grateful.
