Activity Forums Avid Media Composer Work flow for file base Multicam Projects
  • Work flow for file base Multicam Projects
    Posted by Mike Jeffs on April 3, 2012 at 5:41 pm
    Just wondering if there is a preferred method for getting file based media into MC 6 for a Multicam project using an offline online workflow?
    The original 6 camera angles are recorded to an Omneon spectrum all timecode synced. The spectrum gives me the option of XDcam HD422 50Mbs in a MOV wrapper or MXF.
    Then the files are moved to a central Media sever with its own project partitioned out.
    In MC 6 should I Import the original source material at its native resolution of XDcam, then after the import transcode to a low res offline format for the edit. When the edit is complete relink back to the import online footage.
    Or should I Link AMA to the original source clips then transcode to the offline resolution and then relink back to the AMA clips for Export?
    Or is there a third way that I’m not aware of that is even better.
    Mike Jeffs
    Video Coordinator
    BYU-Idaho
    Richard Sanchez replied 14 years, 5 months ago 6 Members · 8 Replies
  • 8 Replies
  • Richard Sanchez
    April 3, 2012 at 5:57 pm
    I would AMA link, transcode to offline and then relink back. I’m sending you copy of my XDCAM workflow guide via Facebook (I figured better than post your e-mail address on a public forum). Hope it helps.
    Richard Sanchez
    Los Angeles, CA
    “We are the facilitators of our own creative evolution.” – Bill Hicks
  • John Pale
    April 3, 2012 at 6:00 pm
    I guess my first question would be why bother with low res offline? If you used DNX36, it’s not really saving much space over full res XDCAM 50 mb/s , is it?
  • Mike Jeffs
    April 3, 2012 at 6:38 pm
    [Richard Sanchez] “I would AMA link, transcode to offline and then relink back. I’m sending you copy of my XDCAM workflow guide via Facebook (I figured better than post your e-mail address on a public forum). Hope it helps.”
    I would love to see your xdcam workflow that would be awesome
    Mike Jeffs
    Video Coordinator
    BYU-Idaho
  • Neil Goodman
    April 3, 2012 at 9:49 pm
    might not save much space, but might run smoother with 6 angles in dnxhd 36
    Neil Goodman: Editor of New Media Production – NBC/Universal
  • John Pale
    April 4, 2012 at 3:43 am
    [Neil Goodman] “might not save much space, but might run smoother with 6 angles in dnxhd 36”
    Ah yes. Probably right about that.
  • Steve Pankow
    April 4, 2012 at 7:26 pm
    Could you post that guide as a downloadable link from here using Cow’s file upload feature?
  • Fredy Schwerdtner
    April 5, 2012 at 1:10 pm
    That would be awesome !
    iMac 2.7 GHz Intel 4 Core i5
    16 GB memory
    MacBook Pro 17″
    2.5 GHz Intel Core 2 Duo
    6GB 667 MHz DDR2 SDRAM
    OWC RAID 5 with 3TB
    (2) External HD LaCieMac (400/800 FW and USB)with 500GB -(2) USB External HD Western Digital (in cases) with 750GB
    OS X 10.6.5
    Final Cut Studio “3”
  • Richard Sanchez
    April 5, 2012 at 5:03 pm
    3954_rjsworkflowguide022012.pdf.zip
    I included a disclaimer to explain the circumstances of our show / workflow. It’s been a big work in progress, but this iteration has been solid from ingest to online thus far. Hope it helps!
    Richard Sanchez
    Los Angeles, CA
