Activity Forums Adobe After Effects Work Area Shift
  • Work Area Shift
    Posted by Tudor Baican on January 5, 2023 at 2:26 pm
    Hello Friends,
    my script shout just shift the work area start point.
    If the start point is smaller the current time it’s work fine,
    but if it’s bigger the start point don’t fit and the duration also change to a bigger value. ???
    What’s wrong here?
    Thanks for your help
    var activeComp = app.project.activeItem;
    activeComp.workAreaStart = 5;
    activeComp.workAreaDuration = 2;
    Tudor Baican replied 3 years, 8 months ago 2 Members · 2 Replies
  • Walter Soyka
    January 5, 2023 at 3:25 pm
    Your script should work fine. This is a bug. I suggest you report the bug and write a work-around function to repeatedly attempt setting the workAreaStart and checking for success. (Looks to me like it works on the second attempt.)
  • Tudor Baican
    January 5, 2023 at 3:49 pm
    Ok, lot of thanks…seems to be bug.
    It works on the second attempt!!
    I set the workAreaStart two times and it work properly.
