Work Area Render Settings
Hi There,
Does anyone have any idea if you can change the settings which Premiere renders the work area too? The problem I’m having is that when I go to sequence > Render Entire Work Area it renders fine but changes the aspect ratio of my footage.
I suspect it has something to do with the size of my footage. It is square pixel 4096×1746.
Thanks for the help
James.
