Activity Forums Adobe After Effects Expressions work area out point
  • work area out point
    Posted by Quico Encinias on April 7, 2011 at 8:02 pm
    I cannot figure out what the syntax for reading the work area out point as an expression. I need to have a bunch of expressions trigger 1 sec prior to when the work area out point is set so that it will animate out at the right time and be a variable length according the the out point.
    thanks,
    quico
    Roger Betin replied 6 years, 4 months ago 5 Members · 6 Replies
  • Dan Ebberts
    April 7, 2011 at 9:00 pm
    Do you mean the end of the work area (the one you set with the “N” key)? Expressions don’t have access to that. You could set a comp marker there and access that, I guess.
    Dan
  • Quico Encinias
    April 7, 2011 at 10:27 pm
    Thanks for the response. Seems like a glaring omission and should be an accessable comp parameter. Im setting up a template to render out a variable length transition. I hope it gets added in cs5.5 I guess ill use a comp marker, it just adds more work on the end user.
  • Jamie Bradshaw
    April 7, 2011 at 10:46 pm
    Just in case you weren’t aware and they of any help, you can also use these.
    thisLayer.outPoint;
    or
    thisComp.duration;
    JimJam•Graphics
    https://www.jimjamgraphics.com/
  • Paul Hasas
    September 5, 2019 at 9:01 am
    8 years later … is it still the case that expressions don’t have access to the work area in / out points?
  • Dan Ebberts
    September 5, 2019 at 1:35 pm
    As far as I know…
    Dan
  • Roger Betin
    May 2, 2020 at 12:12 pm
    Under AE Extendscript try to use workAreaDuration and workAreaStart
    var myComp=app.project.activeItem;
    var workAreaInPoint = myComp.workAreaStart;
    var workAreaOutPoint = workAreaInPoint + myComp.workAreaDuration;
