Activity Forums Adobe After Effects Work Area Duration for 2 renders of same comp
  • Work Area Duration for 2 renders of same comp
    Posted by Brian Mills on July 17, 2012 at 1:09 pm
    Is there a way to set up the work area duration for 2 renders of the same comp? I have a comp i only need to render 2 separate 1 second sections from it. I can set up the 1st 1 second section with the work area duration bar. But the 2nd 1 second section I have to set the time manually in the render settings. Is that the only way to do this?
    Brian
    Andrew Somers replied 14 years, 1 month ago 3 Members · 3 Replies
  • Walter Soyka
    July 17, 2012 at 1:29 pm
    Not directly — but there are a couple scripts you could use.
    https://www.crgreen.com/aescripts/ (look for Queue Comp Sections)
    https://aescripts.com/queue-work-area/
    Walter Soyka
  • Brian Mills
    July 17, 2012 at 1:34 pm
    Thanks that helps
  • Andrew Somers
    July 17, 2012 at 10:21 pm
    ALSO, if you click on the render setting (i.e. “best settings”) you can specify the specific frames you want to render.
    Set the TIME SPAN to CUSTOM
    In the above example,the first frame is set to frame 50, and the last one to frame 100, irrespective of the work area setting.
