Activity Forums Adobe Premiere Pro Work Area Bar
  • Work Area Bar
    Posted by Norman Lafranchi on April 28, 2006 at 7:34 pm
    Is there a quick way to draw the work area bar around a specific clip? This is so that I can quickly export a clip from a sequence without having to tediously drag the beginning and end of the work area bar around the clip.
    Craig Howard replied 20 years, 5 months ago 3 Members · 4 Replies
  • Craig Howard
    April 28, 2006 at 7:39 pm
    I use the short cut keys
    Pg Dn to end of the clip then ALT “]”
    Pg Up to head of the clip then ALT “[”
    (or any other way you can position the CTI to the work area you want to select)
  • Norman Lafranchi
    April 28, 2006 at 9:54 pm
    Thanks, that’s it!
  • Baz Leffler
    April 29, 2006 at 3:15 am
    [Craig Howard]
    Pg Dn to end of the clip then ALT “]””
    If you do this you get one frame of the next clip so you should frame bump back before you ALT “]”
  • Craig Howard
    April 29, 2006 at 5:38 am
    I have never experienced that and I do it a lot – I will check it out.
