Activity Forums Adobe After Effects Words to layers in after effects..is there a script?
  • Words to layers in after effects..is there a script?
    Posted by Jon Draper on September 29, 2009 at 9:43 am
    Good morning..
    I’m looking to see if there is an easy way to break up a sentance into individual layers in after Effects.
    I’m using Cs4, and have a lot of text to enter, it wold be much easier to enter a sentace, break it up and animate as needed. I don’t want to use the text animator controls as more control is needed.
    I’m sure someone must of found a way to do this?
    Any help would be grand, I’ve found some forum posts but never a simple answer to this common problem.
    Regards
    Jon
    Jon Draper replied 16 years, 11 months ago 3 Members · 5 Replies
  • Daytona Swarbrick
    September 29, 2009 at 2:59 pm
    use illustrator and make each sentence or word (which ever you want to group together) a different layer. Import to AE as composition cropped layers.
    That should work.
  • Adriano Moraes
    September 29, 2009 at 3:00 pm
    Hi there. You might want to look here. I believe they have one of those. Just search and you´ll find it.
    https://aescripts.com/
    Hope it helps.
    Cheers.
    adriano
  • Jon Draper
    September 29, 2009 at 3:22 pm
    thanks but nope…
    I’d checked before, and I’ve just checked again.
    There is a ‘decompose’ script but that breaks your text up into individual letters rather than words.?
  • Adriano Moraes
    September 29, 2009 at 3:49 pm
    Oh!
    I really thought I saw something like text2layers one day. But I guess it was a dream. There´s the create 3D text but I don´t know if it could help you.
    This other one breaks the paragraphs into layers. But again I don´t really know if it would help you. Just another shot.
    https://www.crgreen.com/aescripts/
    (crg_Text_from_File.jsx)
    Hope you can find one that suits your needs somewhere.
    Good luck!
    adriano.
  • Jon Draper
    September 29, 2009 at 4:14 pm
    Hi thanks for that link, not bad but still not ideal.
    It would work well if the text was all supplied as a nice text file.
    The ideal would be:
    A script that creates a small dockable window with a one click button. If not this then a normal run script would work ok.
    Then you type what ever text you like,
    Press the button/run script and have it break that text into individual layers for each work. Basically duplicating the layer for the text, and keeping any settings already on it, 3d position, motion blur on, material parameters etc.
    Cheers…maybe I will have to start learning how to do more code than just typing ‘wiggle’ now and again.
