Activity Forums Web Design (WordPress, Joomla, etc.) WordPress site dosn’t work on android mobile
  • WordPress site dosn’t work on android mobile
    Posted by Karsna Ritz on June 5, 2015 at 6:18 am
    Hi
    I host my WordPress site at asphostportal.com. My site works fine on all web browsers but I recently tried it on an android mobile.
    There is a css div called class and all the top of the page is contained within it.
    on the android mobile it can’t display the flash and I get a flash default image but it it is outside the container class.
    The menu at the very top wraps but doesn’t using a web browser.
    I would like this to work on mobiles. Any help on this.
    Kelvin Smith replied 11 years, 2 months ago 3 Members · 2 Replies
  • Curtis Thompson
    June 6, 2015 at 2:34 am
    hello,
    [karsna ritz] ” on the android mobile it can’t display the flash and I get a flash default image but it it is outside the container class.”
    No mobile devices show flash, actually. So any artwork that you have for mobile needs to be HTML5 compliant.
    [karsna ritz] ” I would like this to work on mobiles. Any help on this.”
    your best bet is to find a responsive (that’s the key word) wordpress template – there are a ton out there. I’d search their theme directory to find some, or do some googling. but if you install a responsive theme, then your site will work on mobile. However you will still need to ditch the flash.
    Hope that helps!
    sitruc
  • Kelvin Smith
    July 10, 2015 at 6:24 am
    Which version of Android you’re using?
    It might be because of an older version.
    WordPress Hosting UK
