Activity Forums Adobe After Effects Expressions Word Processor preset with pingPong expression?
  • Word Processor preset with pingPong expression?
    Posted by Chris Harris on August 4, 2008 at 7:49 pm
    I’m attempting to employ the Word Processor preset but would like the cursor to keep blinking at the end of each word or sentence as the text pauses on the screen. How might this be done? Someone asked the same question in 2006, but there wasn’t a definitive answer. The “pingpong” expression was mentioned, but not how to implement it.
    Christopher
    Trent Armstrong replied 18 years, 1 month ago 2 Members · 1 Reply
  • Trent Armstrong
    August 5, 2008 at 3:46 pm
    There were a few things I had to do to make this happen.
    The first was to add an extra letter on the end of the word so the cursor has one more space to go. Otherwise, the cursor just disappears.
    Second, I changed the cursor blink to 10 instead of 8. You might have to adjust this further. 10 is what worked for me.
    I then found the end of the build(right before my final letter appeared) and set a new keyframe there for the Type On slider. I Paged Up a few frames so the cursor disappeared and set another keyframe.
    Finally, I added the following expression to the Type On slider.
    loopOut(“Cycle”,1)
    The loopOut() expression will look at your keyframes and do some sort of looping. “Cycle” means go back to the beginning (or the specified keyframe) and repeat the animation.
    Putting a 1 in the last place there tells the loopOut() expression to count one frame back from the last keyframe and use that as the start of the loop.
    I hope that helps!
    Trent
    Trent Armstrong – Creative Cow Leader
    https://www.dallasaeug.com
