Activity Forums Adobe After Effects Wood Alive
  • Wood Alive
    Posted by Johan Hoogendoorn on September 3, 2007 at 5:00 pm
    I’m working on a videoclip for some friends of mine and am looking fir some artistic advise/ideas.
    Ok, the main idea looks like this:
    https://www.flickr.com/photo_zoom.gne?id=1313232211&size=o
    ‘panes’ of the singer are floating in this wood (sometimes also a lady passes – but not in this pic)
    the camera is slowly (and sometimes not so slowly) zooming in/out, reveals other panes, etc
    The wood is ‘sort of 3d’, generated from a picture, following the Camera Projection tutorial of andrew kramer. https://www.videocopilot.net/tutorials.html
    I’m going add trees.
    But:
    What else could I do to make the wood ‘alive’?
    bees.. falling leaves.. birds..
    any ideas?
    thanks in advance.
    jh
    Johan Hoogendoorn replied 19 years ago 4 Members · 4 Replies
  • Malcolm Desoto
    September 3, 2007 at 6:27 pm
    Maybe add some particles as either dust or fairy type things?
  • Finalrenderfilms
    September 3, 2007 at 7:55 pm
    You could maybe add some birds by using Aharon Rabinowitz technique in part one and two of his bird flock tutorial, found here, https://library.creativecow.net/articles/rabinowitz_aharon/bird_flock1.php, and here, https://library.creativecow.net/articles/rabinowitz_aharon/bird_flock2.php,
    hope this helps a bit.
    Mark
    Final Render Films
  • Mike Clasby
    September 3, 2007 at 8:50 pm
    In your example I think it would look good to play up the misty aspect.
    As a test I did fractal noise on a New Black Solid, chased with Knoll Unmult (to make the dark areas of fractal noise transparent). Knoll is a freebie, here:
    https://www.redgiantsoftware.com/unmult.html
    On a new Black Solid above, add Fractal Noise
    (animate the Transform>Offset within the plugin
    Unclick Uniform Scaling, animate with sliders (increase the Scale width 4 to 5 times as much to get a streaking flowing mist
    Evolution, animate over time for organic movement
    Opacity: 30-40%
    On top of all that I added a duplicate of the Woods, masked off the tree trunks, feathered it so the mist wrapped the trunks a bit, and varied the opacity of the mask depending on how far the tree is into the woods (less transparent the farther in), and it looks nice, like a light mist flowing through the woods.
    Alternatively try muted godrays coming into the woods, or both, mist and rays.
  • Johan Hoogendoorn
    September 6, 2007 at 10:34 am
    wow, these are terrific ideas!
    birds, god rays, mist
    I’ll try it all and let you know
    jochem
