Activity Forums Adobe After Effects Woobles with Motion Morph
  • Woobles with Motion Morph
    Posted by Ian Tucker on June 1, 2005 at 2:25 pm
    Hi all,
    I’m doing what should be a fairly simple motion morph of a peach, morphing from immature to ripe (I’m using motion morph because there is a camera zoom on both shots). The morph looks great except for a few little, well.. woobles is the only way I can describe it. Does any have an idea of what might be causing the images to wooble as they morph. My masks aren’t very complicated so I can’t seem to figure out where the problem lies. Any help would be appreciated.
    I’m using the latest Reflex (2.3.7 I think), After Effects 6.0 on a Dual 1.25 G4, Mac OS 10.3.8
    Ian
    Ian Tucker replied 21 years, 3 months ago 3 Members · 3 Replies
  • Pierre Jasmin
    June 1, 2005 at 2:56 pm
    Do you have “Hold Edges” on? That could cause this.
    Pierre
    wwww.revisionfx.com
  • Shin Kurokawa
    June 1, 2005 at 3:21 pm
    This might help too:
    if you crank up antialiasing and
    check to see Warp/Color Percentages are
    animated smoothly. You can do this
    either by using the Global Percentage
    controls (if they’re checked), or
    on a per-mask basis (more complicated
    in AE but more flexible… no puns
    intended!).
    -Shin
  • Ian Tucker
    June 1, 2005 at 3:37 pm
    Thank you both. Both suggestions seem to be making it look better already. I’ll let you know how it turns out.
