Activity Forums Apple Final Cut Pro Legacy Won’t select drive
  • Won’t select drive
    Posted by Michael Harrington on June 10, 2010 at 3:50 pm
    Strange problem never encountered before. When I attempt to import a file and select import then attempt to select specific drive to select file, the drive blinks and will not allow me to select it. The problem seems to happen when I’m running external hard drives of which are daisy chained via FW800.
    Anyone have this problem or a known reason why this would happen. The problem is not consistent, next day or project everything hooked up same and without problem.
    Michael Harrington
    Mac Pro, Dual Quad-Core Intel Xeon 2.66 GHz, 12 GB, FCP7, Snow Leopard, ATI Radeon HD 4870, 30-inch Cine Display, 4 – 1TB internal, 1.25TB Esata, Numerous FW 800 external drives, MX02Max, FSI 17″ Broadcast Monitor, Mackie 1402 & Event 20/20 monitors.
    John Fishback
    replied 16 years, 2 months ago
    2 Members · 1 Reply
  • John Fishback
    June 11, 2010 at 9:00 pm
    There’s only one FW buss in a Mac. There may be multiple ports, but only one controller. That means that sometimes with two or more devices connected, the buss will choke. While this happens more often when two different devices like a camera and drive are connected, I’ve also seen it happen with just two drives. It probably has to do with the FW chipsets being used somehow not being compatible. Try unhooking the drives one-at-a-time and see if the problem clears up. Maybe hooking them up in a different order may help. If you can move the files using the Finder, but not in FCP, then trash FCP prefs and repair permissions. Perhaps, that will help.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
