Activity › Forums › Avid Media Composer › Won’t record audio
  • Won’t record audio
    Posted by Mark Seymour on December 15, 2009 at 5:58 am
    I am trying to record a clip of dialogue on a Macbook Pro using either an internal or an external mic. I toggle the external deck off, enter a tape name, select A1 and TC buttons as tracks to record, I can see audio levels in the audio tool, I push the record button and the A! button toggles off and the following error is displayed – “Exception: No tracks have been chosen. Please select at least one track”. There was a track selected and now there isn’t. The audio records fine in other applications.
    I am using Media Composer vers. 3.1.3 on a 17″ Macbook Pro 2.93 GHz
    Anyone know why this happens?
    Michael Hancock replied 16 years, 9 months ago 4 Members · 6 Replies
  • Matt Mullen
    December 15, 2009 at 2:35 pm
    If you deselect the TC track does it work?
    Have you tried using the audio punch in tool?
  • Mark Seymour
    December 15, 2009 at 4:19 pm
    Thanks for the response.
    Deselecting TC does not help. The audio punch in tool does work but I would still like to fix the original problem.
  • Michael Phillips
    December 15, 2009 at 4:28 pm
    Can you just record in the other applications and import the resulting audio?
    Michael
    Michael Phillips
  • Mark Seymour
    December 15, 2009 at 4:45 pm
    Yes, I can record in another application but would still like to fix the problem. I was hoping that I had an incorrect setting or something along those lines.
  • Matt Mullen
    December 15, 2009 at 5:15 pm
    I’m not quite sure, I was hoping the punch in would be a valid workaround for you.
    What is the project type? Have you tried other projects/project types as a test?
  • Michael Hancock
    December 15, 2009 at 5:58 pm
    What kind of mic do you have and how is it lined into the computer? Are you running it into an Avid breakout box (Mojo, MojoDX, NitrisDX?).
    Michael
    I’ll be working late.
