Activity Forums VEGAS Pro Won’t go to timecode during cature
  • Won’t go to timecode during cature
    Posted by Sean Simms on May 18, 2010 at 9:57 pm
    SV will read the timecode when i preview but when i do advanced capture it says it can not find the timecode on the tape so i have to reopen the capture window to capture from where i already have the tape cued off….is there a botton i can push that resembles “capture now” in final cut? Now I just get an option to cature from where the tape is cued whenever the capture window first opens up but I can’t go back to that window for my individual clips….
    Mike Kujbida replied 16 years, 3 months ago 2 Members · 1 Reply
  • Mike Kujbida
    May 18, 2010 at 10:22 pm
    Is the time code continuous from the beginning to the end of the tape?
    By that, I mean it didn’t reset to 00:00:00:00 more than once, did it?
    When using the Advanced Capture feature, you either have a batch list already done where you’ve specified several start and stop points or gone through the tape and hit Mark In/Mark Out at all the desired edit points as you’re watching it.
    Either way, a Batch List has to be saved for further use.
