Activity › Forums › Boris FX Particle Illusion › Wondertouch Quality
  • Wondertouch Quality
    Posted by Brandon Curless on July 31, 2010 at 9:03 pm
    Hello, even though I am viewing Wondertouch Paricle Illusion in After Effects CS3 in Full Resolution, all the effects/particles look very blocky and low quality. When I preview the Particle Illusion effects(when I load a new
    library) the effects look great. But when I then take them into After Effects, the quality degrades. Any suggestions?
    Brandon
    Brandon Curless replied 16 years, 1 month ago 2 Members · 4 Replies
  • Alan Lorence
    August 3, 2010 at 9:39 pm
    Sorry about the slow reply. I wonder if this is an OpenGL issue? Make sure you have “Fast Previews” (the lightning bolt icon under the comp window) set to something that does not use OpenGL.
    Alan.
    http://www.wondertouch.com
  • Brandon Curless
    August 4, 2010 at 3:53 am
    thanks for the reply; I tried all the options in the ‘Fast Previews’ preferences but the graphics still look blocky. hmm, not sure why
  • Alan Lorence
    August 4, 2010 at 2:20 pm
    Can you post a screengrab, or email it to support at wondertouch dot com?
    Alan.
  • Brandon Curless
    August 5, 2010 at 3:21 am
    The top pic is what I see when Iam in the ‘Select Emitter’ dialog
    box. But when I click ‘ok’ the graphic(fire) looks like the bottom pic. Any sugestions would be great; thanks alot!
    Brandon
