Activity Forums Apple Final Cut Pro Legacy WMV’s for projector screen
  • WMV’s for projector screen
    Posted by Bronwyn Harvey on June 27, 2008 at 10:54 am
    Hi There,
    I’m trying to make WMV’s for use in a powerpoint presentation that will be displayed on a big screen.
    So far I have just exported them out of FCP. Size 640 x 360. 1 pass variable (no option for two pass), Quality is at 90. Input @ interlaced and output @ progressive. The complexity is at offline normal.
    My other option is to use Soronson squeeze, I applied the powerpoint Hi selection but it shudders when I try play it back (using an uncompressed 8 bit mov from FCP.) I’ve tried all sorts of settings but still I get issues.
    The quality is ok at this size but I’m worried that it will look terrible when blown up.
    Any help would be great thank you…
    Tom Brooks replied 18 years, 2 months ago 3 Members · 3 Replies
  • Richard Harrington
    June 27, 2008 at 3:31 pm
    WMVs don’t work IN a PowerPoint preso… only linked
    Yu unfortunately need MPEG-1 if you want it to play ON the slide
    I recommend looking at PFC media on PC side for embedding video into slides…
    Just feed it uncompressed AVIs
    Richard M. Harrington, PMP
    Author: Photoshop for Video, Understanding Adobe Photoshop, and ATS:iWork
  • Bronwyn Harvey
    June 27, 2008 at 3:42 pm
    Thanks Richard, I think they are linking them… All I know from that side is that they have done it before and are insistent on WMV’s.
    So what does the WMV for powerpoint mean in Soronsen Squeeze?
  • Tom Brooks
    June 27, 2008 at 5:04 pm
    What’s your sequence setting? Are you working in SD resolution?
    I got some decent results from a 1080p29.97 sequence. I used the Windows Media Encoder on a PC to make a 1280×720 file at 29.97fps and a data rate of 4Mbps, progressive. Real nice except for a little hitch in the horizontal movement that showed up only inside of PowerPoint. The finished 1280 movie was inserted on the slide using “Insert Movie from File” and set to play automatically and full screen. It looked pretty great on the big screen.
    If you’re in SD, you won’t get results that good. The PowerPoint Hi setting is nothing special. It’s about 1200kbps 2-pass VBR in Squeeze on my Mac. If you don’t have 2-pass it’s probably because you have a lower end version of Flip4Mac. With 2-pass peak limited VBR, I usually set quality to 0. That makes the encoder favor motion smoothness over sharpness when the bitrate limit is reached.
    I’d go to around 2000kbps for SD. MOst modern PCs handle that with ease and you don’t need much more than that for SD. Low quality deinterlacing is one of the worst problems you face. If you have a high quality deinterlace plug-in for Final Cut (Nattress, e.g.), you’re better off using that before you export for Squeeze.
    Are you testing the results of the PowerPOint Hi compression on a Mac? Not a good test. The only good test is a PC and preferably in PowerPoint on the actual show computer. Windows Media on the Mac is often stuttery in my experience. See if you can Google around and find Ben Waggoner’s “Best Practices for Windows Media Encoding.”
