Activity Forums Adobe After Effects WMV rendering problem
  • WMV rendering problem
    Posted by Yarin Manes on August 17, 2007 at 4:22 am
    i got this strange problem….i want to send as ref wmv file which should be smaller ,i choose all the right settings and render all works great but after the render when i try to play it ,it just dosent work..
    size file is like 600kb,while rendering in quicktime sorenson works fine,maybee its some pack im using i dont know ,i got installed the k-lite pack…you guys recomend anything else? or know whats could be the problem?
    thanks
    granix.
    Kevin Camp replied 19 years ago 2 Members · 3 Replies
  • Kevin Camp
    August 17, 2007 at 1:29 pm
    when i need to create a small media file for email or the web, i will always render out as lossless animation and take that to the compression software to create the smaller file. you will almost always get noticibly better quality and samller file sizes by using this workflow.
    if your compression software doesn’t take quicktime file, uncompressed avi would work equally as well.
    as far as your question, i’m not sure why ae’s wmv would not work, but if you can convert a quicktime or avi to wmv with another piece of software that would be the better way to go.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Yarin Manes
    August 17, 2007 at 3:03 pm
    okie thats good enouf for me the lossless animation i like forgot about it ,hehe , but thing is that after that i must use another program to compress with…slows down…if things can be finished in after effects…which program you use to compress with? regular offline soft?
  • Kevin Camp
    August 17, 2007 at 7:18 pm
    i’ve used both sorenson squeeze and apple’s compressor, both on mac. i like both of them, they are both easy to use and you get good quality for file size…. however, i was not encoding to wmv.
    i know there are several choices for wmv encoding software for pc. but sorry to say i can’t really make any recommednations. but finding software that will make two passes, one to analyze and the other to compress, will help create good quality, low file size media.
    Kevin Camp
