Activity Forums Adobe After Effects WMV exported video has incorrect length
  • WMV exported video has incorrect length
    Posted by Fredrik Bergström on February 19, 2010 at 10:01 am
    We have noticed that when we export WMV video from After Effects the length of the video will not match the length defined in After Effects.
    If we export some video that should be 15 seconds long, and then load the WMV video into ASFView it will tell us that the video is 15:460 (15 seconds and 460 ms) long.
    Any ideas on why this is happening? If we check the meta data (made by After Effects) of the WMV then it will say that the file is 15:000 long.
    It does not matter if the video is 30, 60, or 123 seconds long, it will still be 460 ms to long.
    I do think that the actual video stream in the file has the correct length, but that the header is incorrect in some way.
    /Regards, Fredrik
    Michael Szalapski replied 16 years, 7 months ago 3 Members · 2 Replies
  • Walter Soyka
    February 19, 2010 at 2:52 pm
    I’m not sure why you’re seeing the length mismatch, but exporting WMV directly out of AE is not the best workflow.
    After Effects is not a great compression application. It’s incapable of multi-pass compression, which would generate much cleaner WMV files — less blocking, less banding, and smaller file sizes.
    A better workflow is to render lossless animations from AE and bring them into a third-party compression application, like Telestream Episode or Sorenson Squeeze, or Microsoft’s free WMV encoder.
    Walter Soyka
  • Michael Szalapski
    February 19, 2010 at 3:16 pm
    [Walter Soyka] “A better workflow is to render lossless animations from AE and bring them into a third-party compression application, like Telestream Episode or Sorenson Squeeze, or Microsoft’s free WMV encoder. “
    Or the Adobe Media Encoder.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
