Activity Forums VEGAS Pro wmv choppy playback
  • wmv choppy playback
    Posted by Dan Sherman on August 11, 2006 at 6:44 pm
    .wmv file plays fine from computer.
    But when uploaded and embedded in website playback is jerky, choppy, even some tearing.
    Have rendered every way I know how.
    Any thoughts, anybody?
    Markschneg replied 19 years, 11 months ago 3 Members · 3 Replies
  • Stephen Mann
    August 12, 2006 at 6:46 am
    Framerate is probably too high. What’s your render settings?
    Steve M.
    Stephen Mann,
    MannMade Digital Video,
    San Jose, CA
  • Dan Sherman
    August 13, 2006 at 9:57 pm
    256 kbps at 15 fps
  • Markschneg
    September 10, 2006 at 5:20 am
    Your file could be getting corrupted during the FTP transfer. Though this isn’t the most likely scenario, it isn’t unheard of though. Make sure your transfer mode is set to binary (most ftp clients can auto-determine the setting nowadays), and not ASCII mode. Again, not the most likely thing, but something to look at.
    Also, try tweaking the export to WMV a bit. You’re obviously already dropped to 15fps; try encoding as VBR instead of CBR.
    Lastly, your webserver could be botching the actual serving-up of the file. Again, not the most likely, but may be worth sending a nice email to your host in case you’ve found no other remedy.
    Good Luck.
    -Mark
