Activity › Forums › Adobe Premiere Pro › WMV audio/clip question
  • WMV audio/clip question
    Posted by Ian Collister on May 8, 2008 at 9:39 am
    Hi all,
    Im having to edit .wmv files in Premier. When i drag and drop the clips into the timeline, it automatically puts the audio track into channel 5. Even if i unlink the audio from the video i cant move it to another channel. When i bring in a second or third clip, it continues to drop the audio into the fith channel. I need to be able to use more than one audio channel for this project.
    Can anyone suggest a work around for this? I dont want to have to convert all my .wmv clips to another format as im against the clock a bit on this one.
    Any help is much appreciated.
    Ian
    Ian Collister replied 18 years, 4 months ago 2 Members · 2 Replies
  • Jon Barrie
    May 8, 2008 at 9:58 am
    It appears that the default audio layer type (mono/stereo/5.1 or mono as stereo) is in conflict with your WMV. So it adds a new layer underneath the one’s already there. ie: you have 4 audio layers that are stereo, but the WMV audio is Mono. it will add another mono audio layer underneath the 4 stereo tracks. Check the icon for the type of audio layer it is. That’s probably what’s happening? Keep editing…
    – Jon 😉
    How many editors does it take to change a light bulb?
    http://www.jonbarrie.net
  • Ian Collister
    May 13, 2008 at 7:49 am
    Cheers! That makes sense.
    c.
