WMV as well as DVD
Posted by Steph St. laurent on September 18, 2006 at 7:18 pmHi there.
A client wants me to put two WMV files onto a dvd, that need to also be played back in a home DVD machine. Is this possible? I’m not finding any info on this at all.
As far as I know, as soon as you place something else in or around the VIDEO_TS folders the players wonk out.
Am I wrong?
Help. 🙂
s.
Steph St. laurent replied 19 years, 12 months ago 4 Members · 7 Replies -
Edward Troxel
September 18, 2006 at 7:40 pm -
Steph St. laurent
September 18, 2006 at 8:17 pmOooop.
Thanks Ed. I didn’t see that. I feel like a boob now.
s.
Ted Snow
September 19, 2006 at 7:19 amI do this all the time with Roxio. I just create a data disk and make sure the AUDIO_TS and VIDEO_TS folders are in the root directory of the DVD. Then I just add other directories (in the root directory) for data or what ever. As long as you finalize the disk it will play on set top DVD players, but will also contain any data files you wish to save with your project. You can then just open up the DVD in windows explorer and copy any of the files if you need to later.
Allen Zagel
September 20, 2006 at 12:44 pmI wonder if I’m missing something here or is everyone else missing something? I think that Steph is asking if he can use WMV files to actually create the DVD so they play on the set top player, not as extra data on the DVD for computers.
I did a test a few weeks ago on this one. Brought the WMV files into V5, rendered to MPG and burnt to DVD. I tried it using both DVDA2 and DVLabPro. It wasn’t a very good experience. ha ha
WMV files are small both in size and picture 320 X 240 usually. The resulting DVD was very blocky at full DVD size.
I found a program that will actually convert WMV to AVI but it still can’t expand the picture. So after I converted I had to use the Track Motion to scale the video down a little so it remained sharp. Resulting DVD wasn’t too bad considering all the factors.
If I’m wrong here about understanding the original question, then I’m sorry.
AllenASX Media Productions
https://www.asxvideo.com -
Steph St. laurent
September 20, 2006 at 8:04 pmHi Allen.
No, I was actually asking if I could place the extra data files on the dvd. I know now that I can.
I’ve used some wmv files in MPegs before. It is tricky. If you’re exporting for web viewing in flash it’s not too bad (if the wmv file is over 1mps at least.) I did up a little piece for the local airport using this form and it didn’t turn out too bad. A bit blurry, definitely not broadcast quality, but acceptable for 320/240 streaming…
https://onreelvideo.com/video/airport/airportchinese.swf
Thanks for your help everyone. I love this forum! 🙂
steph
Allen Zagel
September 21, 2006 at 12:34 pmHi Steph
Took a look at the SWF. Nice work! It’s good.
Steph St. laurent
September 26, 2006 at 9:35 pmThanks mucho Allen. Next project I’ll have more keyed time. 🙂
s.
