Activity › Forums › Adobe After Effects › Wispy/thin smoke
  • Wispy/thin smoke
    Posted by Peo Fogelstrom on November 9, 2015 at 8:09 pm
    Hi all,
    I’ve been trying to create some thin/wispy smoke almost all day but come up short all the time. I’m fairly new to using AE i might add. I have looked at a large array of smoke tutorials but I just can’t seem to get my desired effect.
    What I’m looking for is thin (not puffy smoke like sphere/cloudlet particles) that kinda flows at the lower half of the video, maybe at 1/4 of the screen at the bottom.
    The closest I have got is using Particular with a sprite and some Directional Blur. It’s kinda okay but it gets stiff even after playing around with Turbulent Field in Particular and as well as Turbulent Displace.
    Sprite used https://nobacks.com/wp-content/uploads/2014/11/Smoke-15.png
    The reason I’m not using any stock footage is because this is just one of a pitch videos for a introduction to an upcoming online event and the duration is ~1min.
    Peo Fogelstrom replied 10 years, 10 months ago 2 Members · 2 Replies
  • John Cuevas
    November 9, 2015 at 8:59 pm
    Have you tried playing with fractal noise…perhaps something like this: https://www.youtube.com/watch?v=yaH_Z_fc4xs
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Peo Fogelstrom
    November 9, 2015 at 9:07 pm
    Thanks for your quick reply Johnny.
    I was actually thinking what I wanted was more fog so I searched around for a bit and landed on a tutorial with somewhat what I wanted and happen to be just your tip, Fractal Noise.
    https://youtu.be/wMN0Se2XdWg
    This was the result of just a rough draft. It’s a lot better then anything I’ve came up with using Particular. With some tweaking I bet it could be quite nice.
    Now I’m just presented with the problem of getting the smoke to appear without an emitter. But I guess I could change my initial idea from it coming from the side to just fade in the whole scene from black instead.
