Wirelessly transmit audio from a soundboard to the camera
Posted by Michael Tapp on October 13, 2013 at 11:40 pmHi everybody,
I’m a videographer and I am going to be working on a live event gig. The client requested to send an audio signal wirelessly(Sennheiser G2 Set) from the PA soundboard to the camera and for the camera to record the audio. I believe that the PA will be 50 feet from the camera. Since this will be in NYC I thought the radio frequencies might be too congested to send audio 50 feet without getting any interference.
Do you have any ideas on how to send a wireless signal 50 feet without any interference? Thank you for your time!
Malcolm Matusky replied 12 years, 10 months ago 8 Members · 12 Replies -
Richard Crowley
October 14, 2013 at 12:02 amNew York City has the reputation of being one of the big cities known for “RF Hell”.
50 feet doesn’t seem far enough to warrant using wireless between two fixed locations (the PA mixer and your camera). 50ft would be just one length of XLR cable off my reel. If you really MUST go wireless, then rent a professional rig and get expert advice on what band/frequency to use.
I would NOT trust a low-end wireless system to perform reliably in NYC. I would be MUCH more likely to just use a hard-wire connection. Or I would use a separate audio recorder located at the PA mixer. A low-end wireless kit would be my LAST choice.
Do you have appropriate adapters and cables to interface the PA mixer with the wireless transmitter?
Eric Toline
October 14, 2013 at 12:37 amRegardless of which way you go make sure you speak to the house mixer and find out if you’ll be getting a mic or line level feed from the board. If you end up with the Sennheiser G2 and you’re getting a line level feed (most likely) you’ll need an input cable wired for an unbalanced line level into the transmitter. A line feed into the transmitter requires the audio signal to be connected to the ring of the 3.5mm TRS connector.
Eric
“I push the RECORD button and hope for the best”
Michael Tapp
October 14, 2013 at 1:58 amThank you for your advice! It sounds like I am going to have to sell them on running cable or just hooking my zoom recorder into the mixer and monitor the recorder at the board.
Michael Tapp
October 14, 2013 at 2:00 amI am going to try and sell them on recording the audio separately on a zoom H4n recorder located at the board. I am planning on going from 1/4 -> xlr into the H4n. Do you recommend any other adapters for this scenario? Thank you!
Bill Davis
October 14, 2013 at 2:35 amAlso think BEYOND the hardware. The biggest hassle of taking a board feed in a live sound situation, is that they’re typically mixing FOR THE HOUSE.
You don’t specify if it’s a music gig, a speech, or some other type of performance, but if it’s anything other than a “voices only” gig – then you risk having the mix be great for the house but lousy for your recording.
Depending on what you need to record, see if the board op will give you a PFL (pre-fadeer level) channel insert if that serves your needs.
If it’s a music performance, the only REAL solution that won’t lock you into the house mix is grab the channel inserts to capture the individual channel feeds to a multi-track rig.
This is what often makes good sound more difficult to record than good video
Know someone who teaches video editing in elementary school, high school or college? Tell them to check out http://www.StartEditingNow.com – video editing curriculum complete with licensed practice content.
Ty Ford
October 14, 2013 at 2:47 amHello Michael,
Yes, NYC has a very congested RF environment. You are well served by the suggestions here. There is one other suggestion. If you use Zaxcom transmitters with on-board recording, if the signal doesn’t get to the Zaxcom receiver, it will still be recorded on a miniSD card in the transmitter.
Regards,
Ty Ford
Cow Audio Forum LeaderWant better production audio?: Ty Ford’s Audio Bootcamp Field Guide
Ty Ford Blog: Ty Ford’s Blog -
Peter Groom
October 14, 2013 at 9:30 amYou could always try the radio mic approach AND insist on the zoom as a backup.
Im ALWAYS very nervous where the audio recording on which you rely is an un attended recording.
Is the house mixer going to mic to the optimum levels for a recorder?
If it goes too low or high, is he going to respond to your recorder and adjust – I doubt it.
PeterPost Production Dubbing Mixer
Peter Groom
October 16, 2013 at 9:30 pmJust to add to my last post….
Today I was vision mixing and camera directing a stage presentation at a conference for live broadcast to the web.
Given my backgound as a post dubbing mixer, you can imagine I’m tricky to mix audio for!!!
The av sound guy looked at me like I was mad when during rehearsal I stopped the rehearsal and asked him why I was seeing faders open from the panel mics whilst the main pres was on. I explained that I only wanted the current speaker in the mix at any one time sitting on a bed of low but constant fx bed mics.
His day just got complicated
“How will I know who will speak” he said
When I direct them too I said. Watch the screens and listen to the cue feed….. Be in top of it , but I don’t want a mushy all up mix!!!
The point…. There’s a wide variety of experience and expectations outside of a studio. You should presume someone else will mess it up until they prove they won’t.
Ty Ford
October 17, 2013 at 12:32 amWell said, Peter.
While working with hotel AV staff here, they usually don’t listen with headphones, only speakers where ever they are in the space and yes, pots up.
One speaker was clearly off mic and when I brought AV’s attention to it, it was like they didn’t hear it. I don’t know where that mic was, but it wasn’t on the guy speaking. We could hear him Waaay off mic.
story 2: I was hired by a shooter to corral the AV audio and feed it to his camera. I did. As we started he was shocked that my levels hit -6 and told me it would distort. I told him I’d put it anywhere he wanted, but that I was listening to the headphone return and it was not distorted.
He said, “NO! This is digital. No peaks over -20! (yes, no peaks over -20!!) I told him that I’d do that but only under protest. Things got pretty chilly after that. He emailed me later that the first part WAS distorted. I replied that he was probably trying to bring audio in from a line level into a mic level input on his editing setup. I told him to rewind the tape in the camera, plug in headphones to the camera and listen. If the first section was distorted, then his camera was way out of calibration. Besides, even if it was, I wold have heard the distortion. I never heard back from him.
Audio is a mystery to some people. Because of this. I have a job.
Regards,
Ty Ford
Cow AUdio Forum LeaderWant better production audio?: Ty Ford’s Audio Bootcamp Field Guide
Peter Groom
October 17, 2013 at 6:27 amVideo based people often really struggle with audio I find.
PererPost Production Dubbing Mixer
