Activity › Forums › Broadcasting › Wireless transmitter from camera to TV
  • Wireless transmitter from camera to TV
    Posted by Dmitriy Dribinskiy on September 4, 2012 at 9:47 pm
    Hello,
    I am looking for the wireless on-camera transmitter to send HDV signal from the camcorder to the TV. Can you recommend one? Sound is not too important. Would be used at the night club. Thank you!
    Sareesh Sudhakaran replied 14 years ago 3 Members · 6 Replies
  • Sareesh Sudhakaran
    September 5, 2012 at 3:17 am
    Which camera are you using, Dmitriy?
    https://wolfcrow.com/blog/ – Workflow information and support for filmmakers, photographers, audiographers and videographers.
  • Dmitriy Dribinskiy
    September 5, 2012 at 12:51 pm
    Hi Sareesh, I use HXR-NX5U.
    September 6, 2012 at 4:40 am
    Look no further than the Teradek CUBE-150 1 channel HD-SDI. It has a range of 300 feet (90m) and you don’t need anything else – except HD-SDI cables.
    You can also stream live on the internet and record H.264 directly on a laptop or hard drive at the same time.
    Also, you can stream the video via wifi to the mobile phones of the clubbers…cool?
    Hope this helps.
    September 6, 2012 at 11:04 am
    Great, thank you! One question – how do I get signal on TV?
  • Aleksander Steffensen
    September 6, 2012 at 11:42 am
    You’d have to feed the signal from the Teradek cube decoder to the TV. If your TV does not have SDI in, I reckon you can purchase a HDMI decoder.
    Steffensen Multimedia
    September 6, 2012 at 12:45 pm
    The signal is transferred via WiFi – most modern displays have in-built wi-fi. First check if your monitor has it. If yes, check if the specifications match.
    If no to either, you could use an HDMI receiver like this one or connect a wi-fi receiver/router to a laptop, DVD player or Media player and connect that to the monitor.
    It’s not hard.
