Activity › Forums › Event Videographers › wireless mics
wireless mics
Posted by Derek Woods on August 10, 2006 at 3:03 pmI’m considering buying this new azden dual wirelss pkg. Anyone have any thoughts on azden quality or are using this particular Mic pkg?
https://www.azden.com/shop/customer/product.php?productid=93702
Trig Simon replied 17 years, 4 months ago 3 Members · 3 Replies -
Doug Graham
August 10, 2006 at 3:32 pmI haven’t used that particular model, but the Azden UDR line in general is a pretty good value for the money. I have the UDR-500 and like it, though the RX is too large to mount on a small handheld cam.
The UDR-200 is a dual channel system, so you can receive signals from two microphone transmitters at once, and record one to the left channel and the other to the right channel.
What you give up is a diversity receiver. Instead of each RX antenna receiving the SAME signal, and the unit deciding which is the strongest and clearest, each antenna receives a DIFFERENT signal. This increases the chances somewhat of getting an RF dropout. However, the convenience of having two mics in use at the same time may outweigh this.
As with any wireless, check the operating frequency range against other UHF users in your local area. Digital television stations, especially, are providing increased sources of UHF interference in metropolitan areas.
Regards,
Doug Graham -
Trig Simon
May 19, 2009 at 3:56 amAre 200UDR and 300UDR comparable to the 500UDR which I have.
I want to add two receivers at the camera operators station to communicate (one way)
what do you think? I am transmitting from a 51BT
Trig
