Activity Forums Audio Wireless Mic
  • Wireless Mic
    Posted by Fbtony on July 29, 2006 at 6:43 pm
    I am using a Sony HVR-A1 with sennheiser G2 radio mike and wish to have the onboard mike aswell.
    currently I have this setup,
    sennheiser-input 1
    onboard mic-input 2
    INPUT 1
    Rec CH-CH1
    Input level-line
    +48v-off
    INPUT 2
    Input level-mic
    +48-on
    Is this right?
  • Bouncing Account needs new email address
    July 29, 2006 at 8:44 pm
    [FBTony] “sennheiser-input 1
    onboard mic-input 2
    INPUT 1
    Rec CH-CH1
    Input level-line
    +48v-off
    INPUT 2
    Input level-mic
    +48-on
    Is this right?”
    It is right, if the Sennheiser has a line-level output, otherwise it should be feeding a mic-level input (still no need for +48v).
  • Fbtony
    July 30, 2006 at 9:35 am
    Thanks for the reply.
    The problem was, too much sound volume from the sennheiser, now adjusted the audio output level of the receiver from LEV+12 to LEV+00 it seem OK.
    What are the best setting for the for this?
    I will be recording an interview with tie mic by a busy road.
    ta
    July 30, 2006 at 5:48 pm
    [FBTony] “What are the best setting for the for this?”
    There is no “best setting” for every situation.
    It all depends on the microphone you have connected to the transmitter, the placement of the mic, the loudness of the voice, and the input sensitivity of the camcorder.
    Its adjustable so YOU can make the correct decision at the time of the recording (and it will not always be the same at every shoot).
