Activity › Forums › Audio › wireless mic noise
  • wireless mic noise
    Posted by Stephen Ramsey on February 24, 2006 at 2:14 pm
    We have the sony uwp series mic. set. I have eperienced hiss in the audio when the talent speaks a lot of the time. You can cut the high end and no hiss. Any thoughts on the hiss?
    thanks
    Todd
    Will Salley replied 20 years, 7 months ago 2 Members · 1 Reply
  • Will Salley
    February 27, 2006 at 1:56 am
    Probably due to a malfunctioning or poorly designed compander circuit. All analog wireless systems will introduce noise (hiss) into the audio, some models do it more than others. Some models of the more expensive brands will have more noise than a cheaper system – and sometimes it’s environmental.
    Try operating the system with no mic plugged into the transmitter; if you still hear the same level of hiss, it’s probably a bad cable, external RF, or a design issue. If you don’t hear hiss, then the compander circuit may be the problem (still a design issue, but at least you know it’s not a bad cable, etc.) If, when a source is transmitted through the system, the hiss “follows” the signal level, it is probably the compander.
