Activity Forums Apple Final Cut Pro Legacy wireframe re sizing
  • wireframe re sizing
    Posted by Brettw on February 28, 2007 at 11:53 am
    I have 2 video tracks, that I have been editing to run in synch with one another. I have re sized the 2 video tracks in the canvas with the wireframe, so they fit inside the canvas so I can edit them together.
    Now, I wish to export each seperate video track, and have each track resized so it’s the original, full aspect ratio 720×480 video clip.
    Is there a way to restore the original size, within the canvas or sequence, other then going through and manually using the wireframe to make each clip the original size?
    Brettw replied 19 years, 7 months ago 4 Members · 5 Replies
  • Rafael Amador
    February 28, 2007 at 12:11 pm
    Just double click the clip in the time-line and get them open in the brownser window. Open the motion tab and set Scale to 100.
    Cheers,
    Rafael
  • Andreas Karoliussen
    February 28, 2007 at 1:20 pm
    select all your clips in the timeline, and choose “remove attributes” (option command V)
    select “basic controls”.
    If you have other controls or key frames in your “basic controls” these will also disappear, so you might want to make a copy of your timeline first…
    Andreas
  • Andy Mees
    February 28, 2007 at 1:23 pm
    select all the clips in the timeline then press cmd-opt-v to bring up the “Remove Attributes” dialog.
    put a check in the “Basic Motion” checkbox and make sure all other options are unchecked.
    note: this will remove all basic motion attributes from all clips whether you wanted to or not! if there are some clips you don’t want to affect then be selective in your selection.
  • Andy Mees
    February 28, 2007 at 1:26 pm
    snap
  • Brettw
    February 28, 2007 at 6:58 pm
    amazing, thanks very much
