Activity Forums Apple OS X Wired USB Mouse Not Recognized after long sleep. Old Mouse needs new driver.
  • Wired USB Mouse Not Recognized after long sleep. Old Mouse needs new driver.
    Posted by Adam Berch on December 27, 2015 at 3:58 am
    I have a fairly new USB wired mouse (6 months old) and an old Microsoft Optical Optical USB mouse.
    When I plug in my new mouse and put the computer to sleep for a few hours, when I wake it up it says there is no mouse available and it wants to set up a Bluetooth mouse. Why is this happening? How can I fix it?
    With my old mouse plugged in, when it wakes from a long sleep it is fine, no problems. The only thing is that while using this mouse, it skips around sometimes. I’ve done some research and it says that there is no Driver for this mouse that works with OS X.
    Finding a solution for the new mouse or getting a driver for my Old Microsoft Optical USB Mouse, would be greatly appreciated.
    Any help would be great.
    Thanks in advance
    IMac
    5K Retina
    El Capitan 10.11.2
    16 GB RAM
    Mariah Hernendez replied 6 years, 6 months ago 4 Members · 5 Replies
  • John Rofrano
    December 27, 2015 at 4:12 pm
    Is the new mouse an Apple mouse? I’ve never had problems with my wired USB Apple mouse working after sleep mode.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Adam Berch
    December 27, 2015 at 5:15 pm
    No it’s not an Apple Mouse.
  • John Rofrano
    December 27, 2015 at 7:19 pm
    [Adam Berch] “No it’s not an Apple Mouse.”
    I’m guess that something about it isn’t compatible then. I would try using an Apple mouse. If it doesn’t give you any problems, then you know it’s not your Mac… it’s just the non-Apple mouse.
    You can pick up an Apple Mighty Mouse wired USB mouse at OWC for $19 USD.
    ~jr
  • Paul Hillman
    July 12, 2016 at 7:50 pm
    If the mouse works normally, just fine, with the computer, why would it stop after sleeping? Makes not sense to me.
  • Mariah Hernendez
    March 25, 2020 at 3:35 am
    So you are telling that you put your mac to sleep and then your mouse is not working and it wants to connect to a blue tooth mouse?. How does it even make sense?. You have to check your mouse in other mac as well and see if the mouse is okay or not. Did you get any cd for your mouse?. If you did then install it.
