Activity Forums Telestream Wirecast or not for live production?
  • Wirecast or not for live production?
    Posted by Jeff Heywood on November 5, 2013 at 7:51 pm
    I’m bouncing between wirecast built system and blackmagic stuff. To me it seems on the positive, wirecast is much more flexible on the sources. To the negative, a lot rides on your computer performing well.
    At it’s simplest I’m looking at live-streaming public lectures. Generally one cam, one PPT output, and a feed off a mixing board.
    More complex I could see bringing in other sources IP cams are a possibility and occasionally using it for multi-camera google hangout setups.
    We’ll be live streaming to youtube. Does wirecast make sense for us?
    I can see all the features but I imagine some of it is hardware limited.
    Also I need to know if I have video coming from one camera, and audio coming from a mixing board, will sync be an issue?
    Craig Seeman replied 12 years, 10 months ago 2 Members · 1 Reply
  • Craig Seeman
    November 5, 2013 at 8:13 pm
    [jeff heywood] “I’m bouncing between wirecast built system and blackmagic stuff. To me it seems on the positive, wirecast is much more flexible on the sources. To the negative, a lot rides on your computer performing well.
    Wirecast works with Blackmagic stuff.
    You still need a computer to perform well with Blackmagic.
    [jeff heywood] “At it’s simplest I’m looking at live-streaming public lectures. Generally one cam, one PPT output, and a feed off a mixing board. “
    Which Wirecast can handle easily.
    [jeff heywood] “More complex I could see bringing in other sources IP cams are a possibility and occasionally using it for multi-camera google hangout setups.”
    Which Wirecast can do.
    [jeff heywood] “We’ll be live streaming to youtube. Does wirecast make sense for us?”
    Google seems to think so.
    https://www.telestream.net/wirecastforyoutube/cb-landing.htm
    They mention it specifically. After all there’s a version specific to them including Wirecast Play for YouTube which is free
    https://support.google.com/youtube/answer/2907883?hl=en
    [jeff heywood] “I can see all the features but I imagine some of it is hardware limited. “
    Or to put it another way. Software itself is not limited. Get the hardware you want and expand as needed.
    [jeff heywood] “Also I need to know if I have video coming from one camera, and audio coming from a mixing board, will sync be an issue?”
    It depends on the sources (signal path, video decoding). Wirecast Pro has audio sync delay of up to one second.
