Activity › Forums › Telestream › Wirecast hangs up while loading
  • Wirecast hangs up while loading
    Posted by Chuck Pullen on December 12, 2011 at 8:09 pm
    My Wirecast has been hanging up on “loading video” while loading. Any suggestions as to what this might be?
    Chuck
    Chuck Pullen replied 14 years, 8 months ago 3 Members · 18 Replies
  • 18 Replies
  • Craig Seeman
    December 12, 2011 at 9:37 pm
    It can be any of a score of reasons. Please list your complete specs, sources, software versions and I can narrow it down.
  • Amy Wood
    December 21, 2011 at 4:12 pm
    I am having the same issue Chuck. Any resolution?
  • Craig Seeman
    December 21, 2011 at 4:58 pm
    Sorry but it’s hard to offer help if you don’t provide details. There’s scores of reasons this can happen and, given how many people are using Wirecast without this issue, it’s generally a problem with your config.
  • Chuck Pullen
    December 21, 2011 at 5:13 pm
    I feel like my issue is with Logitech, any chance you are using one or more Logitech web cameras with Wirecast?
    Craig, It seems that the issue popped up after the latest Wirecast update. I was thinking of rolling back to see if that might be it.
    Chuck
  • Craig Seeman
    December 21, 2011 at 5:47 pm
    You can role back but I’d like to report the issue to Telestream. They’d need to know the cause to fix the bug.
    You should remove all peripherals (drivers and related software as well, I know, a pain) and add them back one at a time after each reboot and see what happens. Of course if you think it’s a webcam, start with that. I’m using both a Logitech C910 and a Logitech Quickcam Vision Pro (which is a modified 9000) and both, even at the same time, don’t cause any crashes for me.
  • Amy Wood
    December 21, 2011 at 6:16 pm
    As a matter of fact I am using a Logitech C910. What are you using? I am using Wirecast Pro 4 as well
  • Chuck Pullen
    December 21, 2011 at 6:46 pm
    I’m also using a C910 as well as a Quick cam. I’ve tried using more than two webcams, but the Wirecast (and the system in general) becomes unstable. I know that if you manually close the Logitech camera control program before booting Wirecast, it seems to load eventually, but with the program open, it seems to always hang up on “loading video”
    Chuck
  • Amy Wood
    December 21, 2011 at 6:48 pm
    What are your system specs?
  • Chuck Pullen
    December 21, 2011 at 7:03 pm
    I think it is a 64-bit Windows 7 machine, with an i7 940 processor, 12 GB of Ram on an ASUS board, I’ll have to check on the graphics card, but I think it is a decent GeForce. Basically it’s a powerhouse that should have no problem handling this, so it’s definitely got to be a driver issue with the Webcams. I know that I have a similar issue with my home machine and Sony Vegas not loading when my Logitech webcam is plugged in.
    Chuck
  • Amy Wood
    December 21, 2011 at 7:15 pm
    Your machine should have no issues at all. Definitely enough power. I am in the process of removing all peripherals, and I will let you know if it works. Thanks for your help so far. I am new to the board and the business, so hopefully this will help me. I know from some past experience Logitech can cause nightmares with driver issues.
