Activity Forums Telestream Wirecast 2 Camera Audio Feed
  • Wirecast 2 Camera Audio Feed
    Posted by Lindsay Barker on August 16, 2010 at 11:56 am
    Hi All,
    I have a question regarding wirecast and live streaming audio from 2 cameras.
    If I have 2 cameras, both firewire input into a macbook pro (one through firewire port and one through express card slot), is it possible to tell wirecast to only take the audio feed from 1 camera? If so how?
    I want to be able to switch from a looping quicktime playing before a 2 camera interview.
    I have 2 mic feeds going into camera 1 for the audio, so I don’t want to cut to camera 2 during the stream and have no audio…..I need to also be able to switch back to the quicktime audio afterwards.
    Lindsay
    Jeff Mack replied 16 years, 1 month ago 2 Members · 1 Reply
  • Jeff Mack
    August 16, 2010 at 6:37 pm
    Go to Layout and select Layer Panel. There you will see a list of layers pop up on the left. Select audio tab and all of you audio sources will show up. Then select the audio layer for that camera.
    Jeff
