Activity › Forums › Maxon Cinema 4D › Wire collected around a frame
  • Wire collected around a frame
    Posted by Maria Valente on June 8, 2012 at 9:51 am
    Hello Everyone! I am trying to animate a wire being collected on a frame. The wire is linked to a rotating arm and this arm rotates around the frame.
    The attached file ( 4245_wirecollectedonaframe.c4d.zip ) is an initial animation showing the system rotating. When the animation is played the vertical arm rotates around the central frame. What I am trying to achieve is to have a wire going from the vertical arm to the frame that is being collected on the frame as the arm rotates around the frame.
    These two sketches show what I would like to achieve:
    Any help would be much appreciated!
    Marilu
    Maria Valente replied 14 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
