Activity Forums DaVinci Resolve Wiping memories
  • Wiping memories
    Posted by Emilio Batungbacal on February 7, 2011 at 1:55 pm
    Is the mem mix button on the Resolve panel implemented?
    On the Da Vinci 2K+ it was fairly easy to ‘split the difference between two memories by simply selecting both memories on the panel, hitting the mem mix button on the secondary panel and then mix them using the t-bar.
    Emilio Batungbacal
    Colorist
    ZAP! Visual Effects
    https://colorist.batungbacal.com
    Emilio Batungbacal replied 15 years, 7 months ago 4 Members · 4 Replies
  • Darin Wooldridge
    February 8, 2011 at 6:54 pm
    I don’t think spilt the diff came over to the resolve..
    I miss it.
    NOTE: The comments above are strictly mine, and may not necessarily
    represent those of my employers.
    Darin Wooldridge
    Colorist / Technical Strategist
    818-653-3918-cell
    dwooldridge@mac.com
    check me out at https://www.facebook.com/pages/Davinci-Resolve-Colorist/117363011609028?ref=….
  • Sascha Haber
    February 9, 2011 at 9:34 pm
    Me too.
    Not that I ever used it, but my clients always go like : Ok, I like what you did here, no go half back to the original/last version/the reference.
    For that to do I need a channel mixer, or adjustable blend modes or a wipe between two versions..
    A slice of color…
    DaVinci 7.1 OSX 10.6.6
    Dual Xeon 2,4 RAM 24 GB
    RAID0 8TB eSata 6TB
    GTX 285 / GT 120
    Extreme 3D+ WAVE
  • Rohit Gupta
    February 10, 2011 at 2:05 am
    There are two ways to do this. You can use a layer mixer to mix back the original. Add a layer mixer at the end, and connect the second input to the original connector.
    Often, all you need to do is to tone down the effect of a given node. Use the Post Mix control to control the opacity/effect of each node.
  • Emilio Batungbacal
    February 10, 2011 at 2:15 pm
    Thanks guys!
    @Warren, yes I’ve seen all your vimeo vids. Helped me a lot transitioning from the 2K+
    Emilio Batungbacal
    Colorist
    ZAP! Visual Effects
