Activity Forums Adobe After Effects wiping effect
  • wiping effect
    Posted by Zachstar on October 12, 2005 at 5:02 am
    hi i want to produce an effect that that uses a graphic image to wipe from one scene to another for example using this effect to go from an instant replay back to a live game if any one could guide me through this process i would appreciate it
    thanks
    Zachstar replied 20 years, 11 months ago 2 Members · 2 Replies
  • Steve Roberts
    October 12, 2005 at 12:10 pm
    1. Create the image and drag it into your composition. Make it as tall as (or taller than) your final movie.
    2. Make sure (by adjusting its scale) it touches the top and bottom of the screen at the same time.
    3. Animate the logo’s position property across the screen using keyframes.
    4. Render the movie with an alpha channel (composition>make movie) to the Quicktime Animation codec. To make sure it has an alpha channel, make sure the Output Module is rendering to millions+ and RGB+alpha. Check with your editor to find out exactly what format he/she wants.
    5. The editor will then drop this graphic into the show to cover the edge of a regular wipe. He/she may need to tilt the edge of the wipe, depending on the design of the logo.
    That’s one way.
    Steve
  • Zachstar
    October 12, 2005 at 6:02 pm
    hi actually i should have been more specific i want to be able to craete the wipe as well
