Activity Forums Apple Final Cut Pro Wipes on objects in FCPX
  • Wipes on objects in FCPX
    Posted by Johan Moeskops on August 23, 2013 at 11:15 am
    Hi.
    I wonder, if I put a wipe on an object, so it comes in on a background, the background wipes with the effect.
    What’s going wrong, it it possible to make it so, that the background is straight and the object comes in with the effect?
    Thanks a lot.
    Regards, Johan
    Johan Moeskops replied 13 years, 1 month ago 2 Members · 2 Replies
  • Don Smith
    August 23, 2013 at 11:41 am
    I had to read your post twice to understand what you are saying. It appears that you have a background video layer and another clip above it and you want to put a wipe on the clip above to make it appear over the background clip below.
    If this is the case it sounds like you’re using an effect with a Dropzone layer and that Dropzone layer will affect all video below. Right-click on that effect to Open in Motion, delete the Dropzone and save under another name.
    Or, try putting the upper layer in a Compound Clip. Then open the Compound Clip on its own timeline and put the effect on the clip there. Sometimes the Compound Clip will isolate the effect.
    Don Smith
    NewsVideo.com
  • Johan Moeskops
    August 24, 2013 at 2:16 pm
    Hi Don.
    Oke, I understand, I must make a compound clip of my object.
    Thanks a lot, it’s a simple solution.
    Regards, Johan
