Activity Forums Adobe After Effects Wipe / Fade based on honeycomb pattern
  • Wipe / Fade based on honeycomb pattern
    Posted by Wilhelm Hagberg on June 29, 2017 at 12:28 pm
    Hi. I’ve created an Illustrator document with a honeycomb pattern. The illustrator file has 260 layers (each a hexagon) . I’ve imported the illustrator file as a composition into AE. Now i want to create several Wipes with this pattern and later use them as Alpha masks to reveal images.
    Obviously I can achieve this by adding a fade to each layer and then move the layers around until they fade up in a neat order but it’s extremely time consuming with all the layers. Is it possible to do this by scripting?
    I would like to do the equivalent of a linear wipe but instead of the “line” it should use the hexagon shapes.
    Best-
    Wilhelm
    Walter Soyka replied 9 years, 2 months ago 5 Members · 5 Replies
  • Richard Garabedain
    June 30, 2017 at 4:38 pm
    well yes…but only if they are in the correct order…you could set them all to fade on..select all the layers starting from one end…make all the layers 1-3 frames long. go to keyframe -animation – sequence layers…then re-extend all the layers..and there you go….If they are not in order..well then i think you could do this using the shape replicator option in after effects
  • Mark Whitney
    June 30, 2017 at 4:43 pm
    I’m wondering if this might be something done rather quickly in Element 3D and with considerably fewer items to manage.
  • Blaise Douros
    June 30, 2017 at 7:05 pm
    In your original document, if you fill each hex (or each line of hexes) with a different ascending or descending grayscale value, you could use a gradient wipe with the hexes as the source.
    June 30, 2017 at 7:21 pm
    Ya it works pretty easily with element so long as you use another layer to fill in the gaps between the hexagons..such as a simple linear wipe
  • Walter Soyka
    June 30, 2017 at 8:52 pm
    This is also very easy to do with Trapcode Form: use two layers of Form with a custom hexagonal particle to generate the honeycomb (one for the odd rows, one that’s offset a little horizontally for the even rows), then use layer maps or gradient maps in Form to create the wipe.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
