WinXP Deck Control Software playout shifts the colors to blue
A grayscale ramp is generated in After Effects, rendered with the Blackmagic 10bit Codec and then played out with the Blackmagic Deck Control Software via a DeckLink Pro Card (SD via SDI) and gets a blue shifting in the Colors.
A complete test description can be found here:
https://www.onlinevideo.ch/werbemail/Blackmagic_Deck_Control/
Dear Blackmagic Team.
The problem with the blue shift in the Deck Control application began with the Blackmagic Driver Version above 5.2.1.
Is the Deck Control application with the DeckLink Pro card not supported any more?Best regards,
Yves
