Activity Forums Canon Cameras Wing-flap Ghosting
  • Wing-flap Ghosting
    Posted by Dale Spetz on September 28, 2007 at 1:49 pm
    I am experiencing a “ghosting” problem on footage of the flapping wings of birds, from my XH-A1. The shutter speed was at 1/500 f12, which I thought would have been plenty fast enough.
    I have captured in both NeoHD and Vegas7—same ghosting result.
    I have viewed this on both my LCD and my TV ext. monitor.
    I have tried to eliminate by switching to progressive field, but no luck.
    Is this fast motion a limitation of the XH-A1? Or, it this, once again, “pilot error” of some sort?
    Dale Spetz replied 18 years, 11 months ago 2 Members · 2 Replies
  • Donald Berube
    October 1, 2007 at 2:39 pm
    f12 is too small of an aperture to use with a 1/3″ sensor in general… you most likely should have utilized the built-in Netral Density to limit the light going through the lens and perhaps used a shutter speed no higher than 1/250.
    – Don
    DONALD BERUBE
    https://noisybrain.com
    https://www.bosfcpug.org
  • Dale Spetz
    October 2, 2007 at 12:57 am
    The camera was on autopilot when these settings occured. I will not make this mistake twice.
    Do you believe that these extreme settings would explain this double exposure of fast moving objects, like flapping wings?
    Thank you for your reply.
