Activity Forums VEGAS Pro Windows setting or Vegas plug-in to convert color text to B/W from screen recorder
  • Windows setting or Vegas plug-in to convert color text to B/W from screen recorder
    Posted by Tony Lewis on December 9, 2014 at 9:02 pm
    Capturing a short video of my laptop screen when using Google to do a basic search. Google being Google, has text with multiple colors. When I drop the Sony black and white plug-in on the video, the colors come out light grey, particularly the blues and greens. Is there a better plug-in that could convert all text to black or near black, or conversely, is there a setting buried in Windows 7 to generate a monochrome screen (time travel!)? I have gone into the settings for the laptop’s graphics system and there does not appear to be a setting to generate monochrome display.
    Tony Lewis replied 11 years, 8 months ago 2 Members · 2 Replies
  • Frederic Baumann
    December 9, 2014 at 10:38 pm
    If I understand correctly, you might add a “Levels” effect on top of the black&white one, with the “Input start” set at 0.8, and I think it does the job. You may check at the still below:
    Hope this helps, best regards,
    Frédéric
    FBmn Software: Professional GPU-powered plug-ins to fix White Balance and Exposure issues in a few clics.
    Color-matching made easy with the ColorMatch plug-in.
    Want to learn on Sony Vegas Event Pan/Crop tool? Watch my tutorial.
    Or about Keyframes? Watch this one. French version here.
  • Tony Lewis
    December 10, 2014 at 12:19 am
    Merci mon ami, je vais essayer votre suggestion.
    This works well for text only, although it does tend to blur the letters somewhat. When you bring up a page with a photo, a setting of 0.8 is a little too much, 0.3 worked best for me.
    Thanks for the tip!
